'36 Model D head bolt torque spec.
Lyal Purinton
11-02-2004 11:13:51
Anyone know the torque spec for the head bolts on a '36 D? Being new to the engine rebuilding task I am also wondering what is the purpose for the lead washers.
Thanks,
lp.
art from louisana
11-04-2004 13:49:13
 Re: '36 Model D head bolt torque spec. in reply to Lyal Purinton, 11-02-2004 11:13:51
This from Service Manual for John deere Tractors and Engines,Pages 27 and 28.When cylinder head is put back on tractor,soak cylinder head gasket ten minutes in water,shellac both sides and place smooth side of gasketnext to cylinder. Use lead washers under each nut and draw nuts up uniformly and tighten thoroughly.I guess that how they did it "those days". Dont forget to use non detergent oil in crank case. Art
Bob-Wyo
11-02-2004 19:19:08
lp- the head bolts are 208 ft pounds,(1931 to 1953) in 20# increments.
Use 1 lead washer per stud, save the other 9 till next time, they seal the head/stud from water and oil leaks and also good lube for when tightening head nuts.
Hope this helps, good luck on my favorite model tractor.
Bob
lp.
11-03-2004 17:24:27
 Re: '36 Model D head bolt torque spec. in reply to Bob-Wyo, 11-02-2004 19:19:08
Thanks much for the info. I'll torque it down and see if I can get it running.
Thanks again,
lp.
