Extra Solenoid at Starter on 4020D
JerryM
11-02-2004 05:07:46
I have a ford solenoid wired ahead of the starter solenoid on my 65 4020D. The started is 12 volt. The tractor was converted to 12 volt before I bought it. Why are there Two solenoids? Can I eliminate the extra one? It is also in the way of installing the shield on that side. Thank you in advance for any help.
jdemaris
11-02-2004 06:22:33
 Re: Extra Solenoid at Starter on 4020D in reply to JerryM, 11-02-2004 05:07:46
Technically, it's not a solenoid, it's a relay. It's purpose is to extend the life of the ignition switch and make starting more reliable. The pull-in windings on the starter-solenoid take a fair amount of current, and the relay eliminates the need for the starter switch to carry that current. So, yes, you could remove it and things might work okay if your starter switch is working perfect. I usually wind up doing the opposite and ADD relays to all my equipment. In the mechanical context, a "solenoid" uses electrictiy to accomplish mechanical movement- like moving and engaging a starter drive - whereas a relay uses electricity to remotely open or close electrical contacts - but not create mechanical movement. The starter solenoid already does this to a degree. Besides moving the starter drive, it closes electrical contacts that might be carrying 800 plus amperes - but does so by only using 4-10 amperes. By using the relay, you cut down that 4-10 ampere load on the starter switch down to - depending on the relay, as low as one half of an ampere. Another reason why these relays are often used is to make it easier to "wire-in" saftey switches into the starting system - i.e. and e.g. clutch safety switches, neutral safety switches, etc., &c.
Bob
11-02-2004 06:16:46
The extra solenoid was put on the 12 Volt conversion to carry the relatively high current needed by the big solenoid's coil, rather than putting that current through the ignition switch or starter pushbutton, and neutral start switch.
It would PROBABLY work without the smaller solenoid, but it's probably more reliable WITH the added solenoid.
If it is in your way, you could extend the wiring to it, and move it out of the way. I believe Deere had a kit at one time to install the extra solenoid, that mounnted it up inside the dash console, and extended a wiring harness down to the starter.
