40 Battery
MS
02-08-2004 13:14:58
The battery on my 40 is 6 volt, but the negative terminal is only 1 inch lower then the fuel tank. Is this battery to tall?
Henry J
02-08-2004 18:53:03
 Re: 40 Battery in reply to MS, 02-08-2004 13:14:58
MS
That is about the same distance I have on my 420, since it has bothered me in the past. This summer when I hope to get it back together again, I plan to put some sort of rubber/insulator safety cap over the top of the batt terminal closest to the gas tank. Don't know, maybe over four decades ago they make the 6 volt batteries shorter. I am so jumpy about that set up that I usually take the ground cable loose from where it attaches to the pedistal before I start jockeying the batttery around in the box and then undo the terminal clamps after I slide the battery out from beneath the tank and reverse that process when I install the battery.
tom
02-09-2004 07:43:02
 Re: Re: 40 Battery in reply to Henry J, 02-08-2004 18:53:03
Hi Henry,
That is a very good procedure to follow about any time you work near or on the battery--to disconnect the grd terminal...one spark or arc and it to that green place in the sky!!!
tom
Clooney
02-08-2004 13:28:59
MS, I would have to go out to the barn & look to give you an exact measurement but 1" sounds a little tight [it seems like it was more like a couple of inches]..
~As long as it clears & won't hit under flexing or vibration it will be good..
~I know it's tight in there & that is why Deere used that fold down L/H side battery tray to allow the battery to slide out for work on the cables & for filling.
[email protected]
