I have some questions
CK Richard
11-01-2004 17:26:38
first how many c.i . is a 77 (6030)
second does any one have any info on the GMC trucks that had the john deere engines ,I think the late 80's
thanks Richard
leon
11-02-2004 05:05:14
 Re: I have some questions in reply to CK Richard, 11-01-2004 17:26:38
In the mid '80's Deere experimentally installed 6-466, 6-619 and 8-955 engines in several over-the-road and construction dump truck fleets in the US and even a few in Canada. The engines succeeded quite well and the operators liked them. The primary reason Deere elected to not go commercial with them was the product liability associated with on-road vehicles. Later there was a run to get Deere engines in one model of GM truck, but that deal fell apart. I think some brouchers may have been circulated on how to retrofit that truck model with a Deere engine. There was even an early run at AM General aimed at getting the Deere 6-359 engine in the military HUM-V. That was a narrow escape. This is very straight skinny. As Elmer Keith would have put it, "Hell, I Was There!"
bomberridge
11-01-2004 23:03:57
 JOHN DEERE ENGINE INFO in reply to CK Richard, 11-01-2004 17:26:38
here ya go boys>>>> the jd 6030 had a 531a engine in it not a 513 or 619. the 619 or 10 litre was first introduced in the 8630 tractor, both of these engines had weak blocks with the higher horsepower crankshaft, cylinder head and upper sleeve counter bores failures were high in the 619 because engineers used the block as part of the frame, which caused the block to become distorted and fail. John deere used the 12.5 litre engines in trucks but did not pass emissions, the 955 v-8 was also tested and worked good with 475 hp rating, it also did not pass emissions and has low torque which trucks require and had crankshaft problems. john deere engines now are the tier 3 engines 6135 engine is the current engine now used in the larger machines and have no intention of introducing them into the truck market.
Leland
11-01-2004 21:06:28
I think JD put those engines in trucks to show that they could operate at any range. and could take stopping and starting just to show what good all around engines there were.
Mike M
11-01-2004 18:07:40
I'm thinking those 6030's used a 619 ci engine. I picked up some literature from John Deere around 1987 about those engines for GMC trucks,I think I still have it. I don't think any were ever put into production.
msb
11-01-2004 20:08:49
 Re: I have some questions in reply to Mike M, 11-01-2004 18:07:40
I know of one that was used OTR.WE had it go through our shop several years ago.Think maybe it was overhauled at the time.I can't remember.
CK Richard
11-01-2004 18:56:38
mike john deere told me that they made some experimentl models all LP .just would like to know what size engine . could you send me a copy Richard
Mike M
11-02-2004 17:16:15
 Re: I have some questions in reply to CK Richard, 11-01-2004 18:56:38
Richard; I just dug up my literature it was from JD's 150th aniversery in 1987. The engines were for medium duty trucks two horsepowers 215 @2200 rpm and 240 @2200 rpm models 6466A and were to be marketed through Detroit Diesel Allison to power or to repower your truck. Turbocharged and intercooled. Also have some info that offers a repower kit for S1900 series Navistar Chassis marketed through Hinklin Power Co. in Des Moines Iowa. The info I find most interesting is the brochures on the John Deere --Score (trade marked name) 70 series ROTARY ENGINES These were listed in 1,2,3,and 4 rotor models Model 1007R 1 rotor 80 BHP and 198 lb weight model 2013R 2 rotor 160 BHP and 253 lbs model 3020R 3 rotor 240 BHP and 366 lbs model 4026R 4 rotor 320 BHP and 430 lbs this is dated 07-87 and states that by 1994 a power growth version at BHP ratings of double those listed for each model.States all kind of wonderful features.Wonder what ever happened to them ?
buickanddeere
11-01-2004 18:28:46
513 turbo in the 6030 except for a handfull of 513 5020 spec engines. The 619 was introduced in the 40 series. The tail end of the 466 production exceeded the rated 175 HP 531 by 25+HP. Real world they were close.The 619 got stretched to about 260HP. The late model 8.1 which is still traced back to the 4010 makes at least that much HP on less fuel and emissions. The 9.0L version will be wilder yet.
