Clutch Question, No Snap
Thornton Mellon
11-01-2004 17:02:42
the clutch (early styled '47 b) wont snap into place. If I hold the clutch lever forward the clutch engages but doesnt snap into place or hold if the lever is let go. The castellated nuts were torqued to 10 ft-lbf, but this wouldnt allow disengagement of the clutch. backed off until clutch worked, but still no snap. Would the problem be the springs, the pins attached to the toggles, or the slack in the shift fork splines? (Or combination of all). I dont see a spec in the service manual for the pins.
Can the splines on the shifter fork be repaired and the casting bushed to remove the sloppiness of these parts?
buckeye al
11-02-2004 15:08:11
 Re: Clutch Question, No Snap in reply to Thornton Mellon, 11-01-2004 17:02:42
Are you certain the clutch was in the engaged position when the nuts were torqued? When you say if torqued to 10 ftlb, it wouldn't allow disengagement, makes me think either your clutch slid back into the disengaged position while you weren't watching as you tightened up the nuts or 10 Ftlb was just too tight for your tracotr!Suggest backing the nuts way way off. Take a tarp strap & use it to hold the handle forward. Tighten the bolts uniformly finger tight to remove all slack. Then torque if you desire or I prefer sneak up on it turning all three nuts one castle at a time & try the clutch action repeatedly.
BEFORE testing the feel of the clutch, I always (each time) re-install the cotters & then turn both the nut AND bolt watching to see (or feel) where it falls into the typical worn spot in the dog's fork inside the pulley. If you don't do this to every bolt every time before you try them for feel, the bolts will move to this position eventually & then you'll have a slipping clutch.
New springs make them feel nice especially the late lettered series and numbered tractors (more plates) but won't affect the snap.
Good luck & post back.
Lee B
11-01-2004 23:44:52
Case casting can be bushed to repair wallowed out hole and work on shifter fork splines might pay better with replacement parts but can still be done. Your call on both issues.
It sure sounds like somethings binding in there somewhere as you seem to have done everything right on the money so far and yet it still don"t work. My money is on the worn out splines for what it"s worth but it could be just about anything including upside down or backwards parts installation. Double check everything and resist the urge to force it.
mike brown
11-04-2004 17:52:55
 Re: Clutch Question, No Snap in reply to Lee B, 11-01-2004 23:44:52
There is a dowel pin that the clutch collar slides on that keeps the dogs lined up when the clutch is engaged. If it is broken (mine was) the dogs will turn off to the side as the collar can now rotate and the clutch will not snap in. The dowel pin wears over time untill it get too thin and breaks. It can be replaced.
