JD 60 Head Bolt Pattern
Barry Rhoads
11-01-2004 08:04:10
Can anyone tell me the position of the two longer bolts for the JD 60 Head to Block Bolts. Tractor number is 6059324 and is a gas tractor. I did not pay close enough attention when I removed the head. Have new head bolts and lead washers. Need bolt locations for long bolts.
Many Thanks
Barry Rhoads
11-04-2004 06:16:07
 Re: JD 60 Head Bolt Pattern in reply to Barry Rhoads, 11-01-2004 08:04:10
Gentlemen,
I believe that you are correct. I re-looked the parts book, it seems to indicate that there should be one longer bolt. The other eight are the shorter variety. If anyone has any other thoughts, I would appreciate your sharing them.
Thanks!!!
Barry
Barry Rhoads
11-02-2004 11:50:44
Thanks To All!!! I did remove nine bolts (I think).My 60 has nine bolts. Parts Book calls for nine bolts. I believe that you all are correct on the one. Any ideas on the other one.
Mike N Mo
11-01-2004 15:54:49
Barry
There should be only 1 bolt longer than the others. The long one should go in the middle, and the rocker arm oil line adapter goes under the long stud nut. Hope this answers your question. Mike
Kevin L
11-01-2004 20:37:00
 Re: JD 60 Head Bolt Pattern in reply to Mike N Mo, 11-01-2004 15:54:49
came home to check and Mike N. right by looking at the parts manual and service manual there is one stud 7-1/2" and 8 @ 6 and something inches long. the long stud gones in the middle or stud #1 and also holds the oil line in place. kevin
Mike M
11-01-2004 10:12:13
I don't know for sure,but how are your rocker arm stands held on this model ? maybe the longer ones go there and they use a coupling nut and a bolt like on a 720D ?
