JD 1020 tire pressure
Cleo
10-31-2004 15:30:03
I just purchased a JD 1020. Do you add air to tires that have liquid in them? Can too much liquid be put in tires?
mowr
10-31-2004 19:10:48
 Re: JD 1020 tire pressure in reply to Cleo, 10-31-2004 15:30:03
Follow the tire air pressure guidelines listed in the owner's manual. Maintain the same air pressure with or without fluid. Generally 14 psi for 4 ply tires and 20 psi for 6 ply.
old
10-31-2004 17:28:54
all the fluid is for weight and you have to have air in them about 15-20psi. and yes you can have to much fluid in a tire. It should not be over about 3/4 full, that leaves room for expansion when the tire heats up.
