4630 or 4240
JRK
10-31-2004 15:26:53
I am in the market for a new Tractor 100 HP or higher and would like to know what models are good. I already have a 4230 and it is a great tractor, but I hate to take off and put on the duals all the time. I plan on using this tractor for purposes that don�t require duals like hauling wagons, knifing in Nitrogen, blowing snow ect�
I would really like a tractor that starts relatively well in cold weather as the 4230 starts very hard when it is cold.
A local JD dealership has two tractors that look very interesting to me.
1. 1974 John Deere 4630; 150 hp; 3998 hours and powershift transmission
2. 1978 John Deere 4240; 110 hp; 7290 hours and a partial powershift transmission
Does anyone have any recommendations?
I have read some posts about 4630 users having problems with the transmission, is this a common problem with that model?
Should I pass these two models by and wait for something else?
Any suggestions would be great!
Thanks,
Jason
JRK
11-03-2004 09:36:29
 Re: 4630 or 4240 in reply to JRK, 10-31-2004 15:26:53
Thanks to all of you for your advice! I believe you are right. Waiting for a 4440 is probably a very good idea.
pbutler
11-02-2004 02:35:26
I agree with the other post, wait for a 4440. I have a 4630 and it is a great tractor with lots of ponies but starting in cold weather is definately NOT one of it's strenghts.
Below 50 degrees if you don't have either then forget it!
Mike Aylward
11-01-2004 18:34:49
JRK, why not wait for a nice 4440? It would have the nimbleness and usefulness of the 4240 and would rival the power of the 4630 even if the 4440 is rated at a lower level. They are one of the best tractors Deere ever made. Mike
Mark Westphal
11-01-2004 06:20:47
I had a 4240 Quad range that I thought was a very useful low maintenence tractor. The only reason I sold it was that I needed more HP.
I am not too familiar with the tranny you mentioned on the 4240 that you are looking at but it sounds like the Quad range.
Mark
4630
10-31-2004 17:44:13
I would check what updates the 4630 had done to the transmission. I have located a 1977 model powershift that I intend to purchase.
thurlow
10-31-2004 17:31:01
Fewer than 4000 hrs on a '74 4630? could easily be on its third tac/hour meter..... with 10,000 or more actual hours.
edchainsaw
10-31-2004 20:07:30
 Re: 4630 or 4240 in reply to thurlow, 10-31-2004 17:31:01
the 4630 tranny problems were in the quadranges''' we had one.. got it stuck and the 2 little bolts in the front were loose they backed up with the extra torque the mud caused and boom top shaft dropped.. dont happen that way on a power shift..
the 30's didnt start well at all in cold the 40's were a lot better.
so your guess of a 4240 wouldnt be bad. just check your axle barings often.
also the 4630 is 1000' pto only if thats a problem.. ( I had a 4630 and loved it but it was a work tracot duals were always on)
oh and we have a 4430 (77model) that's just got 4000hrs... it was my grampa's.. and we use it to plant with yet so I can believe the one could have that.
