Does 420 Front Hood Emblem Fit 40T??
Charles56
10-31-2004 15:20:27
Can anyone tell me if a 420 JD front (metal oval 4 legged deer) emblem will fit a JD 40T? I have a 40T, and although it is mostly original, I would like to put the above emblem on the upper front hood. Also, it it fits were is the best place to buy one?
Thanks alot...Charles
Ray
10-31-2004 15:58:43
 Re: Does 420 Front Hood Emblem Fit 40T?? in reply to Charles56, 10-31-2004 15:20:27
If the nose has the two verticle holes in the center the 420 emblem will fit,if you have the old style with the two horizonal holes made for
the chrome John Deere script type embem it won't
unless you drill new holes.
Charles56
10-31-2004 16:41:36
 Re: Does 420 Front Hood Emblem Fit 40T?? in reply to Ray, 10-31-2004 15:58:43
Ray,
Thanks for your reply.
The front hood on my 1953 40T does not have any holes drilled. I figured I can drill the holes as long as the curve of the emblem is the same. Also, I am assuming I need the 4 1/2" emblem???
Thanks...Charles
CMB
10-31-2004 16:56:59
 Re: Does 420 Front Hood Emblem Fit 40T?? in reply to Charles56, 10-31-2004 16:41:36
Since your nose dosn"t have holes,are you sure your 40T didn"t originally have a decal here? I have a "54 40U, & it never had any emblem on the nose , just a small JOHN DEERE decal. the letters are only maybe about one inch high.
Charles56
10-31-2004 17:08:54
 Re: Does 420 Front Hood Emblem Fit 40T?? in reply to CMB, 10-31-2004 16:56:59
Hi CMB
Yes my 1953 40T has a decal, but I would like to remove it and put the four legged deer medallion type emblem in its place. I know it would not be original, but for my own satisfaction, I think it would really dress up the front of the tractor.
I need to know if the curve of the emblem will work on my 40T??
Thanks...Charles
krk
10-31-2004 17:56:22
 Re: Does 420 Front Hood Emblem Fit 40T?? in reply to Charles56, 10-31-2004 17:08:54
CMB or Charles 56. To keep a 40T original what decides whether the front badge is a sticker or the chrome John Deere name plate?
