6 volt gen-John T.
Mark
10-23-2003 12:24:55
Change a 6 volt gen. be changed to a 12 volt by changing the windings and voltage regulator on my 40u? The gen. needs to be rebuilt anyway. Thanks..
Mark
10-23-2003 15:15:20
 Re: 6 volt gen-John T. in reply to Mark, 10-23-2003 12:24:55
Thanks John and Wayne, someone told me that a gen. doesn't know what to charge if it wasn't for the regulator. Now I know.
Clooney
10-23-2003 17:47:23
 Re: Re: 6 volt gen-John T. in reply to Mark, 10-23-2003 15:15:20
Mark, actually that's not entirely true or there wouldn't be a difference between a 6 & 12 volt generator.
~While it is true a 6 volt generator will put out enough to charge at 12 volts it does require the engine [& generator] RPM's to be kept higher to put out enough to keep the battery up.
~If you use your tractor during the day or sparingly at night, & run the tractor for a while after start up, & keep the RPM's above an idle, a 6 volt generator with a 12 volt regulator will work OK.... If you run it at low RPM's with the lights on you will be less than happy with a 6 volt generator on a 12 volt system.....
Mark
10-24-2003 10:33:42
 Re: Re: Re: 6 volt gen-John T. in reply to Clooney , 10-23-2003 17:47:23
Thanks, Clooney and others, It's on a 40U that has been a DOT tractor, always been orange and has never had lights. Ser.# 61579
John T
10-23-2003 18:10:32
Mark and Clooney, Thats also why if using a 6 volt generator to produce 12 volts, the fields may be drawign more current than intended, as ALL other things being the same, it would take more field current to produce as much energy at the same RPM. Ive never had one go bad when I used a 6 volt generator with a 12 volt regulator and would still do it, but the fields might eventually go bad. The field current and the resultant strenght of the magnetic field and RPM are main contributign factors in the energy produced when you rotate a coil of wire (armature) inside a magnetic field (produced by field current) to produce energy, but the mass and make up of the iron and overall size and distances and the commutator etc etc are also factors.
Good thread and great discussion here. Thanks guys
God Bless John T
John T
10-23-2003 14:59:52
Hey again Mark, Yep the RIGHT way to change it from a 6 to a 12 volt generator ESPECIALLY if it needs rebuilt anyway, is to change its fields, armature if needed, and use a new 12 volt Voltage Regulator and be sure the new VR is compatible with positive ground if thats how youre running. Dont forget to polarize the new unit once installed and wired up. HOWEVER, Ive changed from 6 to 12 using the same generator JUST a new 12 volt regulator and theyve worked fine, even though the fields may be running more current than intended and the commutator segments seem slightly different. Theoretically, a generator dont know exactly what is supposed to put out, its increased by running more field current (creates a stronger magnetic field) and/or turning it faster.
Take Care n Good Luck Mark
John T
Wayne in Tn.
10-23-2003 15:10:05
 Re: Re: 6 volt gen-John T. in reply to John T, 10-23-2003 14:59:52
Yep, due to some advice from John T. and Clooney. I am currently running an original 6v generator, just bought a 12v regulator and 12v battery. Now I have a 12v system that looks like a 6v.
