Noisy 60
Kemper
10-31-2004 13:31:10
I have a 60 that is noisy in all the gears just when it is pulling, it sounds like it is comming from the right side maybe behind that first gear reduction cover? i'm sure it is not rear end noise, anyone had any similar noises and maybe a cure? the noise is a high pitched whine, i didn't know if the 60's had a habit of wearing out any certain gears or not.
MIKE LOKAI
11-01-2004 18:17:51
 Re: Noisy 60 in reply to Kemper, 10-31-2004 13:31:10
I JUST COMPLETED REPAIRING THE SAME NOISE IN A JOHN DEERE 620. THE NOISE IS COMING FROM THE COUNTER SHAFT JUST BELOW THE FIRST REDUCTION GEAR. THE SHAFT WAS PITTED FROM AGE AND MOISTURE IN COMBINATION WITH SITTING OUTSIDE BOTH THE SHAFT AND ROLLER BEARING HAD TO BE REPLACED. I HAD NO PREVIOUS TRANSMISSION EXPERIENCE WITH THE HELP OF THE PARTS MANUAL AND A RESTORATION BOOK PURCHASED AT TRACTOR SUPPLY THE JOB IS DONE GOOD LUCK, CALL IF QUESTIONS 352-843-0146
John Van Valkenburgh
10-31-2004 19:54:58
My 50 is the same way. I believe it's the first reduction gear. They are straight cut gears and tend to be noisy. I'm told that this is not unusual and unless there are other factors such as grinding or metal flakes in the transmission oil its not something to be worried about.
John
1953 Model 50
