JD 4020 Hydraulic
HaySam
10-31-2004 11:48:56
After about 6 years i found out why my 69 4020
lost all hydraulic when holding clutch down NO HELP from JOHN DEERE !!!!! ! email me i can help you.
I Bleed Green
10-31-2004 12:49:09
 Re: JD 4020 Hydraulic in reply to HaySam, 10-31-2004 11:48:56
What, are you trying to make money off your big secret? Well it's no secret, and John Deere should know what it is. Here it is. The transmission pump that feeds the main hydraulic pump does not run when the clutch is pushed in.
Gerald J.
10-31-2004 15:12:21
 Re: JD 4020 Hydraulic in reply to I Bleed Green, 10-31-2004 12:49:09
For the 68 an earlier there is a check valve in the transmission that leaks and lets the oil reservoir/cooler drain when the transmission pump isn't running. There is a service information on that. I have a rough copy posted on my web page at www.geraldj.networkiowa.com/4020si.htm.
The failure is different in the side console version. I have a service bulletin upstairs on that, but since I don't have the later 4020 I don't have that bulletin memorized.
Gerald J.
Jason Z in MO
11-01-2004 08:53:07
 Re: JD 4020 Hydraulic in reply to Gerald J., 10-31-2004 15:12:21
Gerald,
What are the symptoms of this condition?
Does the cooler drain when the engine is shutdown for a few days? On start up it would take a few moments for the cooler to fill and return hydro pressure.
Gerald J.
11-01-2004 09:35:43
 Re: JD 4020 Hydraulic symtoms in reply to Jason Z in MO, 11-01-2004 08:53:07
In its worst condition, you loose hydraulics as soon as you push in the clutch, e.g. you loose steering, brakes, and remotes. They come back shortly after you start the transmission turning again. Borderline cases may take a few seconds to loose the hydraulics. Same thing when starting after the tractor has been setting. If its all working right you have hydraulic pressure on the first half turn of the crankshaft (so don't push down on the brake pedals, they rise rapidly with force!)
With the check valve working you don't loose hydraulics for some time after pushing in the clutch, though I do a little faster since I added a loader with old valves converted from open center.
Gerald J.
