JD 4010 generator
Lee C
10-31-2004 09:53:17
OK,it appears that the field windings are connected to the field terminal and A1 and that there should be some kind of continuity between those 2 terminals. I"m getting zip, squat, nodda. Is my assumption correct?
Bob
10-31-2004 10:08:02
 Re: JD 4010 generator in reply to Lee C, 10-31-2004 09:53:17
Yes, there should be continuity through the fields. I don't know offhand, what the resistance should be, but it wouldn't be a great amount.
Since the fields on the Deere 24 Volt system always have voltage in them, with respect to ground, any dirt and moisture that pack in next to the windings will start a leakage path that will eventually corrode and break down the windings next to the debris. So bad fields are not uncommon in these Deere 24 Volt generators.
A local automotive electrical shop can probably get the field coils, or they are available from Deere, AR11031 @ about $40.00.
As you probably know, though, the screws holding the field polepieces in place are buggers to get out without the proper tools.
txblu
11-01-2004 05:35:48
 Re: JD 4010 generator in reply to Bob, 10-31-2004 10:08:02
"the screws holding the field polepieces in place are buggers to get out without the proper tools."
I acquired the handiest gadget years ago. It's a hammer operated impact tool that will accept hex bits of whatever your choosing. You can select cw or ccw for the impact.
For this application, you insert your screw driver bit, select ccw, and hit it with a hammer.
Get 2 things: percussion to do the work, and force applied to the screw which helps to keep the tool in the screw.
If you don't have one I'd look around and get one. Real handy.
Mark
Lee C
10-31-2004 10:49:55
Got the field windings out (fairly easily. I must've had something close to the right tool).
Anyway they are soldered together and half of them check good, are they sold in pairs only or can I buy just one?
Bob
10-31-2004 10:54:44
 Re: JD 4010 generator in reply to Lee C, 10-31-2004 10:49:55
They are sold new as a pair, so unless you could find a used pair with the opposite winding bad, you're stuck getting them both.
Reinstall the pole shoes in their original locations, in their original orientations.
Lee C
10-31-2004 09:58:30
I also get a big spark when polarizing the generator. bigger then I ever remember on any other generator.
Bob
10-31-2004 10:10:47
 Re: JD 4010 generator in reply to Lee C, 10-31-2004 09:58:30
Lee,
The reason for the big spark is the voltage that's double or quadruple what you're used to working with... 24 Volts as opposed to 6 or 12 Volts.
The 24 Volts is enough to WELD with!
(So the large spark when polarizing the 24 Volt system is completely normal.)
