730D hydrostatic power steering
mike brown
10-31-2004 08:44:40
The 730D tractors build in Argentina in the 1960's had hydrostatic power steering like the new generation tractors. If one needed power steering work on a 730D, could the hydro. system from later series tractors be installed in place of the original pedestal type. Would it use the same fan mounted pump or need to be plumbed into the bottom pump.
Just a mental exercise at this point.
Gerald J.
10-31-2004 09:14:02
 Re: 730D hydrostatic power steering in reply to mike brown, 10-31-2004 08:44:40
The pictures in the book about the design of the new generator tractors shows a vane type rotary motor for the 730D and the new generation tractors use a double piston motor each piston having two ends for pressure and a rack to drive the rotating shaft. Looks a lot different. Might use the same control valve though. The pressure in the new generation tractors is a lot higher than previous JD tractors, like 2200 psi compared to 1400 psi.
That book says the remaining production machinery for the 2 cylinder tractors was moved to South America. Much was worn out also.
Gerald J.
