4230 diff lock
matthew pepper
02-08-2004 10:56:07
I have a 4230 and the diff lock slips. It tries to lock but does not lock together and the tractor then spins one wheel. Does anyone know if there is a common fault? Could it be the diff lock clutch plates, the piston or the oil control value. thanks for your help.
david val
02-08-2004 13:26:46
 Re: 4230 diff lock in reply to matthew pepper, 02-08-2004 10:56:07
check the pressure by installing a T at the connection of the pressure line behind the right final drive. if pressure is in spec. (which i don't remember, i think 400 something psi) you have a problem in the diff lock brake. if pressure is low - check the valve.
david
