4020 Hydraulic problem
Mike Pihlaja
02-08-2004 10:55:37
I have a John Deere 4020 Diesel with a syncro-range transmission. With Engine idling, when you push in the clutch, the power steering cuts out and you lose the power brakes. Also, I don't know if it's related, but, the 3-point will settle quickly with the engine off, and is initially slow to raise.
Is the problem possibly the transmission pump or the check valve near the pump, or the cooler bypass valve, or could it be another check or relief valve elsewhere in the system? I haven't done any pressure checks on the system as I'm getting ready to bring the tractor into the shop.
Any help or information would be greatly appreciated.
DON
02-09-2004 14:46:51
 Re: 4020 Hydraulic problem in reply to Mike Pihlaja, 02-08-2004 10:55:37
Mike, you dont say what year your tractor is. If it is a 1969 or newer the Hyd. PTO valve could be leaking to sump( High pressure leak)check for heat.check for adjustment. The valves in the remote valve boxes could be leaking to sump, they were good for breaking, does the lever operate smooth?check for heat after it runs for awhile. You say the rockshaft settles that could very well be the leak as the thermo relief valves were good for this. Check the cable adjustment or rod for the correct length, is it trying to raise the 3 point to high? there is a check valve that holds oil in the oil cooler when you shut the tractor down, if it leaks off ,when you start the tractor it has to pump a couple gal. of oil befort the hyd. starts. you may have to plug off the rockshaft and such to isolate these leaks. Sorry for the long post. Don
Bob
02-09-2004 15:30:09
 Re: Re: 4020 Hydraulic problem in reply to DON, 02-09-2004 14:46:51
Don,
That's the conclusion I've come to... that it would be a good idea to plug the feed to the rockshaft, and see if that eliminated the problem.
HaySam
02-09-2004 05:31:52
Have had that problem for five years
no one in this part of the world can figure it out ben to two dealers and about $4,000
still not right.If you figure it out please post.
Bob
02-08-2004 11:50:02
You probably have a high pressure leak to sump. This allows the oil in the hydraulic system to leak away when the clutch is in (transmission pump not running), instead of being returned to the oil cooler, and then to the front pump.
Starting with the tractor at room temperature, the hydraulic component that warms up the fastest is probably the culprit. Sounds like you could have a valve or cylinder leak in the 3 point.
Other possibilities are selective contol valve(s), or steering valve.
