JD 40 Brake Questions???
Charles56
10-30-2004 05:54:06
I am wondering if I should tackle replacing the brake disc's on my John Deere 40 and would appreciate any help on the following questions:
*How hard are they to replace? *Any tips or tricks to insure a good job? *Best place to buy new disc's.
I haven't taken the housing off yet to see what I am up against. Your responses will help to determine if I should give it a try.
Thanks ...Charles
CPeter
10-30-2004 16:50:23
 Re: JD 40 Brake Questions??? in reply to Charles56, 10-30-2004 05:54:06
I think that the amount of work involved depends on what model tractor you have. An "
U" or "S" would be a lot of work. Some of the others are a lot less. as everyone said, be sure it is well supported if you have to remove wheels and housings.
CPeter
johndeereal
10-30-2004 08:09:58
Not a bad job but be sure to replace the axle seals while you have it apart. Be sure you have the tractor well supported as you'll be removing a lot of weight when you pull the axle housing and axle off.
buickanddeere
10-30-2004 09:08:31
 Re: JD 40 Brake Questions??? in reply to johndeereal, 10-30-2004 08:09:58
I wonder which chassis style the tractor is? The T & W models are easy to access.
buickanddeere
10-30-2004 07:32:59
Maybe 1/2 an hour per side. Disks are not cheap, I'll be more careful not to drive with the parking brakes latched on again. I may even mount a limit switch and warning light on the linkage. There is a new one piece adjustment rod/yoke rather the old rod,nut and yoke. Good idea to replace them as they strip or pull through. Some of these jobber shops that re-line brakes and clutches could reface the disks. But for all the time and running around it isn't worth the bother unless you have a spare set of disks ahead.
Wayne s
10-30-2004 06:29:08
Best place to purchase parts for your 40 is from the local John Deere dealer. Be sure when ordering parts make certain that they are for your S/N tractor. Very important!
No big deal to replace these brakes of course you, can't ever go wrong to follow the maintenance/service manual for that model & year tractor which takes you step by step.
