Bigger/Newer engines in 4020
J.D. Jim A
10-29-2004 20:15:27
Just wondering, what's the biggest engine you've ever seen in a 4020? I'm not talking bored and stroked pullers, I'm talking factory Deere eninges. Would a 619 bolt in, or is a 466 the biggest that would fit? Also, what's the newest engine that would bolt in? Did they make any changes to the 466 when they started calling it the 7.6L that would prevent it from interchaging with the earlier blocks? Basically, I'm just wondering exactly how much the basic 4020 engine has changed over the years. One more- is the 531/619 engine a different block than the 404/466?
pete VT
10-30-2004 10:50:08
 Re: Bigger/Newer engines in 4020 in reply to J.D. Jim A, 10-29-2004 20:15:27
Can the transmission and rear end handle the power of the bigger engines ??
msb
10-30-2004 22:27:09
 Re: Bigger/Newer engines in 4020 in reply to pete VT, 10-30-2004 10:50:08
Rear end and transmission no problem. I once bought an experimental 404 turboed Deere engine out of an unnamed turbo manufacturer's test room.It was set at 150 horsepower when I bought it.I put 2000 hours on the tractor with that engine in the tractor before the engine went down.After 2 attempts to rebuild the engine that lasted only a couple hours(4 corner scoring) on the dyno each time,I replaced it with the original engine that I had kept.(Even Deere couldn't tell me what parts were used in the engine)I still have the tractor and the transmission or rear end has never been touched.
buickanddeere
10-30-2004 13:56:31
As long as the tractor isn't ballasted with more weight she should be ok. Horsing it around will cause problems sooner too.
DONMYEIL
10-30-2004 07:12:02
466 WILL BOLT IN. 531-619 ARE MUCH LARGER BLOCKS
DONMYEIL
10-30-2004 07:11:50
buicknaddeere
10-29-2004 20:57:11
The new for 2005 9.0L "small block" six may fit in there. It's a direct decendent of the 4010 engine. About 551 cu inches. That would make an easy 300HP stock spec factory rated.
Ray
10-29-2004 20:25:27
I saw a 4020 with a 4440 engine at an auction
last year.Looked like it fit nice,but the side
panels wouldn't fit because of the oil filter.
Ray
10-29-2004 20:27:12
 Re: Bigger/Newer engines in 4020 in reply to Ray, 10-29-2004 20:25:27
The frames are all the same width on the 4020,
4430,4440.We had a snow blade that fit all 3.
Edchainsaw
10-31-2004 20:22:27
 Re: Bigger/Newer engines in 4020 in reply to Ray, 10-29-2004 20:27:12
JD once touted conversion kits for 4020's to go to 466's (also made kits for 1850,and 55 series olivers as well)
I DO know that my cuz put a 7720 combine engine in my grampa's 4020 power shift... hood will no longer fit.
he tried to pull it at the local pull -- its still in one piece.. the motor is now sick.. LOL
