730 diesel , worn splines , clutch drive.
Derek L.
10-29-2004 12:18:14
The clutch drive to crank shaft,went bad on my 730 diesel. I bought a new clutch drive from John Deere,but it did not take up all of the slack. I don"t think the slack was gonna quite disappear when I tighten the bolt. I thought I would try to repair the splines on the crank. Can I use a wire welder to build up the splines or do I need to use a special rod. I thought I could then cut it back down with a die grinder. What should I try to do? Thanks for any help, Derek L.
Emerald 70D's
10-29-2004 12:56:34
 Re: 730 diesel , worn splines , clutch drive. in reply to Derek L., 10-29-2004 12:18:14
Derek...they make under sized clutch drivers to remedy this common problem. Check with Dengler's, they usually have an ad in the Jd collector magazines.
Jak
10-29-2004 12:54:04
Your gonna have some to tell you to replace the crankshaft but if you want to spend some time you can make it work.I took a G John Deere and welded the worn sides of the splines and ground it down with a die grinder a little at a time trying it a little along till it fit.You can dress them up nicely with a file,just take your time and watch what you are doing.The G was done 4 years ago and is still running right now.
Derek L.
10-29-2004 16:14:03
 Re: 730 diesel , worn splines , clutch drive. in reply to Jak, 10-29-2004 12:54:04
What kind of welder did you use to build up the splines? Did you use an arc welder or a wire welder? If you used an arc welder did you use any special kind of rod?
Thanks, Derek L.
