Front Rims for 1020
Peter S
10-29-2004 07:26:51
I installed a loader on my 1020. The stock 6.00x16 front rims are impossible to use on soft ground. They simply cut in and sink deep!
Can anyone offer advice on the best width rim to use for good floatation? I've seen a 1020 with 11" fronts. Any problems with that? 7.5 = 9.5 seem to be available readily.
What is the offset to order?
Any good place to get rims? I'm not into hunting down rusted and abused stuff, so new is what I'm looking for.
The plan is to be able to get to areas next spring I had to let go this year due to excessive rains.
Thanks!
Gerald J.
10-29-2004 08:19:17
 Re: Front Rims for 1020 in reply to Peter S, 10-29-2004 07:26:51
I went to 11L-16 wagon tires on 8" wide by 16" rims on my MF-135 years ago for that reason. Then I bought a JD 4020 and moved the loader and those tires to it. I changed to 4 rib 11.00-16 for greater ground clearance and better steering. The wagon tires would could take 20 or 30 feet before they'd change the tractor direction while rotary hoeing.
Offset is measured from the center of the rim. You need to be sure the back spacing (from rim to mounting surface) is about the same on the new rims. Look at shoup (www.shoupparts.com) They offer 15 x 8 and 16 x 8 rims with 1-1/8" offset. With the rims probably 4" wider than the original rims that might be just enough offset to not rub the tires on the spindles.
I bought one rim in a rim shop in Des Moines and the other at a used tractor parts place that has since gone out of business. The day I was shopping, each had only one rim available.
It might be that a 9.5L-14 would be a better fit for your 1020, still needs an 8" wide rim and shoup has that too. Maybe 11L-15.
The 6.00-16 shows 36 square inches contact on a flat plate with 13.3" loaded radius. The 9.5L-14 (an implement tire not front steering) has 61 square inches contact on a flat plate and has a 13.0" loaded radius. The 11L-15 tractor front tire has 56 square inches contact on a flat plate and a 14.6" loaded radius. The 11.00-16 tires I'm using on the 4020 would be monsters on your 1020, but I think that's what my neighbor has on his 2020. 84 square inches contact on a flat plate and 17.6" loaded radius. Raised the front of my 4020 about 4 inches, but those big fat tires don't get caught in plow furrows and don't sink into the ground when I've a load of gravel in the bucket.
Gerald J.
old
10-29-2004 08:07:32
On my loader tractor I use 7:50 -16 tires on the front and almost never have trouble with them cutting in unless I'm in mud and then as you know thats where you should be in the first place.
