JD 404 engine uses specs ( hard start q)
FarmerScottWisc
10-29-2004 04:44:09
Hello! Search I may, search I might, come up with this I did not.
I've got a 6600 Sidehill combine with the 404.
I see people talking about putting the 404 in a 4020, SAME engine, or an adequate replacement? How many HP then is the 404 & what other equipment was/is? it used on--
As to the hard starting -- gots to gives it a shotz of ether to start if it's been sitting for 2+ days; within 2 days: pops right off w/o ether. Is fuel draining back? Is there a manual pump anywhere to test this? Anything I can do on this? Ether is harsh, especially if there's reasonable solution.
Thanks!!
matthies
10-29-2004 20:14:11
 Re: JD 404 engine uses specs ( hard start q) in reply to FarmerScottWisc, 10-29-2004 04:44:09
Look at your fuel filter base there should be a 90 degree fitting on the base with the line from the tank. That fitting is a check valve that is supposed to prevent fuel drain back. Pull the filter base and replace that fitting and your problems will stop. chris matthies
4430deere
10-29-2004 05:58:00
the 404 will work in the 4020 we put one in a 4010 out of a 7700 that we pulled a little, once we started winning they dq ed us, any way they will fit but you have to do some work to get them in, the front pulley on the 404 has to be trimmed and some other things has to be made, if you have a good lookin paint job it wont look real good after the turbo gets a load on it. a marine blanket with some trimming will take care of that. upgrade its well worth the money
Steve Geiger
10-29-2004 05:15:22
I have a 6600 level land combine with a 404 in it. I have discovered that if it sets a while the fuel will drain back in the tank. I started to shut off the valve at the fuel bowl below the fuel tank. Never have a problem with it starting from lack of fuel. Just remember to turn it back on before you start it. Next time you start it if it has sat for several days crack the bleeder plug on the fuel filter and turn on the key to engage the fuel transfer pump below the fuel tank, If you get air the fuel is draining back into the tank, start keeping the fuel shut off closed. As to the 404 it was used in the 4020, 4000, 4320, 4520, 4620, 7020, 4230, 4430, 4630, 4040, 6600, 7700, and it think the 105, plus construction equiptment and anything I may have missed that others can add. That is most uses though. SJ
