G exhaust valve cups
Will P
10-28-2004 20:19:33
Working on a 49G and I just can"t imagine what in the world those big cups over the exhaust valves are for. Anyone?
Thanks,
Will P
DPOST
10-30-2004 07:19:41
 Re: G exhaust valve cups in reply to Will P, 10-28-2004 20:19:33
Will;
Rockers don't push in a streight line as they push the valves. When the rocker pushes the valve down, it causes some sideways pressure on the valve stem because the rocker makes an arc as it rotates on the rocker shaft. This sideways pressure or movement is normally gotten rid by the slippage where the rocker contacts the valve.
The idea of the cup is to allow cup to take up any sideways pressures and allow the valve to be pushed in a truly streight line. Since the cups are a much large diameter compared to the valve stem, any binding or wear caused by the sideways pressures is distributed so it is lesser problem.
Did JD really need to put the cups on the G? The A head don't have them and the valves seem to hold up fine. The cup was probably over kill.
Anyway this is probably why the red line on yor G is well below 7000 rpm as the cups adds a bit of weight to the valve train.
Take Care
D.D.Post
Will P
10-30-2004 09:01:34
 Re: G exhaust valve cups in reply to DPOST, 10-30-2004 07:19:41
Thanks, I kind of thought that but I was just wondering if there was some other reason.
Thanks,
Will P
