4010 BRAKES AND PTO
JIM MALL
10-28-2004 17:22:03
HOW CAN YOU GET THE 1000 PTO TO WORK THE 540 PTO W ORKS BUT THE 1000 DOESNT WHEN SWITCHED. ALSO MY RIGHT BRAKE WORKS BUT THE LEFT ONE GOES ALL THE WAY DOWN AND IS SPONGY. I BLED THE LEFT SIDE BUT NO HELP NEED REPLYS THANKS.JIM
msb
10-28-2004 21:14:59
 Re: 4010 BRAKES AND PTO in reply to JIM MALL, 10-28-2004 17:22:03
The brake problem solution is to rebuild the brake valve . Look carefully at both pistons when you take the valve apart and you will most likely see the problem.
txblu
10-29-2004 06:59:00
 Re: 4010 BRAKES AND PTO in reply to msb, 10-28-2004 21:14:59
Brake valve, on right side under floorboard on side of tractor main casting. If it's leaking you can pull up the protective boot, push the pedal down (engine running) and fluid will come out the top. I need to do mine. Maybe this winter I'll do that and my remote valves too.
Mark
RJ-AZ
10-28-2004 20:45:34
Dunno about that brake problem. I'm going to tackle a 4010 on Sat. that has the right brake doing the same thing as your left one. Twopop is right on the PTO.Check that the gear moves freely.
twopop
10-28-2004 20:39:21
when you remove the 540 stub shaft,does the small shaft in the center of the pto,slide out about 3/4 of an inch.if it doesnt,it may be stuck or the spring that pushes it could be broken.if it does move,then,the shift collar pin is bent or broken.this pin can be replaced by removing the front pto bearing quill you also have to remove the bolt in the end of the front pto shaft.
Tx Jim
10-29-2004 05:48:44
 Re: 4010 PTO in reply to twopop, 10-28-2004 20:39:21
Years ago when I worked for a JD dealer there were several 3010/4010's that the 1000 rpm rods were removed allowing only 540 rpm's on pto.Owners got tired of small pin bending or breaking.Maybe your tractor came from Tx. Tx Jim
