How to take compression on 420w???
cmbb
10-28-2004 16:10:10
Gentlemen; Do I turn the engine over once to take the compression or let it turn over multiple times?
What should I get for a compression number on a 1956 420w?
Mike M
10-28-2004 19:00:40
 Re: How to take compression on 420w??? in reply to cmbb, 10-28-2004 16:10:10
Take out both plugs,open throttle wide open as to let in full amount of air,make sure choke is not on,watch the gauge as it builds pressure it should go up pretty high the first time but will usually go a little higher next couple of times just stop when it doesn't go up any higher write the number down do the next one and write it down. The amount of differance if very much say 25 psi or more may be of more concern than actual number. I had a 440 crawler with a similar engine if not the same make 150 psi in each cylinder. I would say if you have 120 up to 150 psi you should be in fine shape.But you still could have good compression and worn out oil rings that let it burn oil.Test it and report back.
cmbb
10-29-2004 02:48:51
 Re: How to take compression on 420w??? in reply to Mike M, 10-28-2004 19:00:40
Mike; Thanks! Will check it out today.
cmbb
10-29-2004 11:18:32
 Re: How to take compression on 420w??? in reply to cmbb, 10-29-2004 02:48:51
Mike; Just took the compression readings. 125 in the front and 120 in the back cyl. She does smoke some but I would like to use it this winter a little plowing snow and pulling some pine logs out. My plan is to overhaul it next year.
Mike M
10-30-2004 05:49:27
 Re: How to take compression on 420w??? in reply to cmbb, 10-29-2004 11:18:32
Is the smoke blue or black ? Blueish would be oil black is overfueled and a good tune up and adjustments can help clear it up. If you can use it some like it is this will help you maybe find out if you need to do some other stuff to it when you do decide to tear into it.
cmbb
10-30-2004 11:15:45
 Re: How to take compression on 420w??? in reply to Mike M, 10-30-2004 05:49:27
Mike; It is mostly blue, the plugs are kind of black also. I took the carb off but could not get the seat out for the jet. The old one looks ok, so will run it that way this winter. Just put in new spark plugs , cap, wires etc. It runs ok just getting tired.
