Spark Plugs
Big Yarber
10-28-2004 09:43:52
over the past couple months i have read several statements saying that people run their spark plugs one - two temp. ranges hotter than stock. is their a reason behind this? what is it? i have never had problems with a stock plug.(gap mine at 44 for all the tractors i run(JD B, IH W-6, HF TO-30, IH 400) and only have a fouled plug once in a while)
John T
10-28-2004 16:10:21
 Re: Spark Plugs in reply to Big Yarber, 10-28-2004 09:43:52
Yarber, The main reason I generally use a plug thats a heat range hotter then specified is cuz I usually dont use the tractor under sustained hot heavy loads as it was designed for. Consequently, potential fouling deposits can accumulate on the plugs which working the engine hotter n harder ORRRRR in the alternative, the hotter plug can help to some degree burn off. The same holds true if shes an oil burner, i.e. more heat can help burn off oil deposits increasign plug use time prior to fouling.
John T
laborintensive
10-28-2004 18:46:32
 Re: Spark Plugs in reply to John T, 10-28-2004 16:10:21
Which plug would you guys recommend for a 3010 LP that is not worked hard or for very long at a time? Its got Champions in it right now . . . which someone told me to get rid of! Probably should change the wires out too.
John T
10-29-2004 07:05:47
 Re: Spark Plugs in reply to laborintensive, 10-28-2004 18:46:32
Sorry Labor, I barely know the 2 cylinder specified plugs but have no experience with them new fangled new generation (heard they have 4 to 6 cylinders lol). While I like Autolite plugs in my 2 bangers, the heat range is probably more important than brand, so you might??? just try one range hotter if shes only used lightly. HOWEVER, the plug fouling problems we talk about in our older single barrel and especially magneto equipped tractors are not near so bad in the dual induction carbs and especially in the later higher compression new generation tractors such as yours, so the specified plug of any brand will likely be fine (especially in cleaner burning LPG) in my opinion.
John T
Duane Larson
10-28-2004 13:02:32
Big Yarber,
There is another reason besides fouling due to an engine that is not up to specs - JD for example in their Field Service Bulletins listed separate plugs for Heavy, Normal, and Light use - tractors came with "Normal Use" plugs. JD recognized that if a tractor spent its life working hard as the primary tractor for field work a colder plug would be best, and if a tractor only saw use for raking hay, pulling wagons, etc. a hotter plug would be best. The colder plug in a hard-working tractor reduces pre-ignition, and the plug does not overheat which increases its life. The hotter plug in a tractor with an easy life reduces fouling due to the fact the plug never gets hot enough to burn off normal combustion products.
Big Yarber
10-28-2004 15:20:24
 Re: Spark Plugs in reply to Duane Larson, 10-28-2004 13:02:32
So, what kind of plug would you recomend when pulling in a tractor pull?
buickanddeere
10-28-2004 20:43:17
 Re: Spark Plugs in reply to Big Yarber, 10-28-2004 15:20:24
For idling while waitng for your turn to pull, hot plugs. While lugging the last lb ft of torque from the engine while pulling, cold plugs.
Duane Larson
10-28-2004 20:41:47
Big Yarber,
I'm not a puller, but I suspect you idle while waiting to pull, then work very hard, then idle again while reweighing and picking up your trophy, so I guess I would go with plugs for Normal Loads. Plugs for heavy loads are normally for heavy sustained loads (ie, several hours of butterfly against the pin load).
txblu
10-29-2004 07:00:32
 Re: Spark Plugs in reply to Duane Larson, 10-28-2004 20:41:47
LIke your optimism. Did you see that RED blow it's top (literally) a couple of weeks ago. Did you see the expression on the driver's face?
Mark
txblu
10-28-2004 13:05:03
I forgot that but totally agree.
Mark
txblu
10-28-2004 12:49:33
Fouling is the reason. For some reason, their old iron isn't up to it's "ponies of new" and has some arthritis or something and puts too much bypass oil or excessive fuel on them keepin them black. So's we ups the heat to burn that crud off. No probems with OEM; great!
Nowin iffin she were diesel..... ..... ..... .
Mark
