Trans making noise / My first tractor
430 Man
10-27-2004 15:55:38
Tranmission makes alot of noise. I just got this tractor. What could be my troubles. Ian
Pete/ME
10-28-2004 02:54:39
 Re: Trans making noise / My first tractor in reply to 430 Man, 10-27-2004 15:55:38
Friend has a 620 that had a noise in the trans. when he bought it 20 years ago. Still does, still uses it. There's noise and there's noise, it's pretty subjective. Best to find a guy familiar with machines and have him give a listen.
andy b.
10-27-2004 18:45:07
Ian,
judging by your screen name, i'm guessing this is a 430? what kind of noise is it making? my 40U makes some noise, but it isn't a clanking or thunking or a real loud whine. it is just "noisy". probably most old tractor transmissions sound similar.
have you checked the fluid levels in the tranny and final drives? if they are low it will make the tranny louder.
andy b.
Will P
10-27-2004 16:03:56
What is your tractor????? A, B, 4440??? All transmisions are different.
Will P
Wayne in Tn.
10-28-2004 08:55:17
 Re: Trans making noise / My first tractor in reply to Will P, 10-27-2004 16:03:56
If you are referring to a 430, you have been given good advice above. It depends on the type of noise. The 40-420-430 models are known for transmission growl, not clunking or clanging tho. Usually some gears will be louder than others, depending on which one was used most. Those trannys have straight cut gears and will make some noise after many years of use. If you don"t have any chipped teeth or bad bearings, about all you can do is change the oil to 140w, that will help some.
