2 ?'s, F.I.T and US B
TIMAR
10-27-2004 07:18:20
1ST of all, I am restoring a 35 B and the power lift piston is stuck in the cylinder. What is the best way to get it out?
2nd ? is to FIT. Can you e-mail me your electrolosis recipe? I see your website is under constrcution and I need it quickly.
F-I-T
10-27-2004 08:32:50
 Re: 2 ?'s, F.I.T and US B in reply to TIMAR, 10-27-2004 07:18:20
On the piston, if oil and such does not work, and air pressure does not work (keep your face away from the open end incase the piston lets go, then I have alreadt laid it on a bed of charcoal on my grill and let it bake. After a while I stomped it on a 2x4 and it came on out. You'll need new seals that way. :)
Article is in the e-mail now.
F-I-T
txblu
10-28-2004 09:15:44
 Re: 2 ?'s, F.I.T and US B in reply to F-I-T, 10-27-2004 08:32:50
If the cylinder is 3" bore and with a 125 psig air source, you're putting 883 pounds of force on that thing. Hopefully that will drive it out, but be careful. That could hurt you bad it it hits you.
I usually put the air on it a little at a time till it plops out.
Mark
TIMAR
10-27-2004 09:15:22
Problem is, the piston is far up in the cylinder, and I cannot get the wrist pin out to take the assembly off of the lift housing. Also, on your Electrolysis solution, do you use both lye and soda, or just one or the other?
