Dan, that is a very common problem on the 40's with the early shift levers. ~While those 40's could have any number of shift related problems form bad trans bearings to worn shifter parts, to worn lever slot or pin, the bent shift lever tractors seem to have the most problems.. ~I have repaired a few of those 40's with shifting problems & unless the trans is worn it usually involves adding a little weld to the bottom of the shift lever or making an oversized shifter anti-rotational pin & [or] welding up the slot on the shift lever fulcrum ball & machining a new groove. ~If a 40 just has a shift lever problem it isn't a big deal to get it to shift correctly.. If a 40 has worn trans gears, a worn countershaft [somewhat common] or worn shift forks & sliders it gets more troublesome & can get expensive.. ~If you are looking at a 40 & the shifting is difficult but it stays in gear good & isn't real noisy in gear it can probably be repaired without much problem.. If it pops out of gear, has a REAL noisy trans, or a grinding sound, or the shift lever moves around when the throttle position is changed you might be looking a expensive repairs.. [email protected]
