CYLINDER QUESTION
MITCHP
10-26-2004 10:59:00
WHEN I PARK MY JD A I USUALLY LEAVE THE HYDRALIC CYLINDER HOOKED UP TO MY PLOWS AND THE POWERTROL PLUGS HOOKED IN THE TRACTOR, MOST OF THE TIME I LEAVE THE PLOWS IN THE RAISED POSITION, KEEPS THEM FROM SITTING ON THE GROUND, GETTING WET, ETC...QUESTION IS, DOES IT HURT THE TRACTOR AND OR CYLINDER TO LEAVE IT RAISED UP? THE PLOWS NEVER DO LEAK DOWN EVEN AFTER 3-4 DAYS, I JUST DON'T WANT TO WEAR OUT SEALS OR ANYTHING THAT COULD CAUSE PROBLEMS LATER
MITCH
CLW
10-26-2004 12:17:11
 Re: CYLINDER QUESTION in reply to MITCHP, 10-26-2004 10:59:00
For safety the plows should always be lowered. Deere says so. This also would take pressure off the system and would keep the tractor from rolling if the brakes are not set.
CLW
Mike M
10-26-2004 11:14:45
I don't think it will hurt your tractor or cyl. but if someone gets to messing around when your not there they could drop it on somebody. Funny how those old power-trols will say up forever and some of the new modern systems can't say up for an hour.
Carl
10-26-2004 22:46:49
 Re: CYLINDER QUESTION in reply to Mike M, 10-26-2004 11:14:45
Maybe a little Viagra is needed in the hydraulic tank on the modern systems. :)
