Can I afford a John Deere???
Tom Willliams I
10-23-2003 11:34:29
I am about to make my first tractor purchase. My own uses will be to carry things , mostly dirt, from one side of my ten acres to another for flower beds and all. It will also be used for mowing grass as well as bushhogging some of the land that has become overgrown. Other than that I want to build some little smooth pathways so my 75 year old Mom can safely ride her electric cart to all parts of the place.
Questions. Is an old John Deere competitive with some of the others?
What are the oldest models with power steering and hydraulics for a front end loader and other items? Can repair parts be obtained as cheaply and easily as for a Massey or Farmall?
Also, want three point hitch and pto to be usable. Is the Deere a type 1 or can it be converted? Does it need to be converted?
Also, what are the earliest models with the live pto and hydrolics.
My budget is so small, around three thousand or so. Can I afford a John Deere??? Am pretty capable as a mechanic and don't mind doing my own work.
Thanks in advance. I know JD people are very loyal and before I buy a Farmall or MF I really do want to know if JD is an option.
Tom Songsmith
Huckleberry
10-24-2003 08:59:08
 Re: Can I afford a John Deere??? in reply to Tom Willliams III, 10-23-2003 11:34:29
I am not any sort of expert...but my experience has been that John Deere is just better...especially the older equipment. Care, use and maintenance, of course, are required for best results. I have found over the years that tho JD may be higher in the original purchase price---new or used. That is good...your tractor will always be worth at least as much as you paid for it. and I have found most John Deere parts to be reasonable in cost compared to Massey for example---I had one Massey part made at a machine shop for 1/3 the price at the Massey parts dealer. Year after year you will find John Deere engineering and design is just the best available. This is just my experience...a tractor becomes like one of the family...that is...one gets emotionally attached over the years. As to which model is best for you---shop around, don't get jumpy...you will know when you have found the right tractor for you. Good luck.
MIKE HANLEY
10-23-2003 18:20:54
I think you may spend alot of time looking to meet you requirements and stay in your price range and still have anything tht can be put rigth to work in any brand. As to a John Deere with Power steering, live Hyds, 3 Point hitch and live PTO. That combination was finally put together starting with the 20 series in 1956, how ever the size JD that would fit your need, beening the JD 420, had more without power steering then ones that had power steering. If your past 40 years of age and want a loader, you will need power steering. A 420 and it's replacement in 1959 and 1960 the 430 would handle a JD 35 loader a 7' rear blade and a 5" rotory mower. If your lucky enought to find a 420, 430 with power steering and a loader you will be above your $3,000 budget. Price range I will stay away from as there is a mind set out there that a certain model is worth a price weather it's a good tractor or a basket case. And if the tractor has been all fixed up the poor guy selling can't get out what he has put in the tractor because of the mind set of what it's worth. There are guys that call a new paint job, restored. The word restored is the most abused word I have ever heard. Parts are no problem. I'm trying to think what would be simular in MF or HI, but I think what you will find in those tractors will be the same as in the 420, 430. In the little tractors in those days, power steering was an option not taken very often.
Tom Williams III
10-24-2003 06:23:49
 Re: Re: Can I afford a John Deere??? in reply to MIKE HANLEY, 10-23-2003 18:20:54
Thanks Mike, and all others. The information you gave seems dead on the money. One of the acres I want to clear in the old days had a few dump trucks of concrete chunks dropped in it.
I want badly to clear this acre and the rest. The largest chunk is probably 800 pounds or so. You are right about power steering. At 53 I am no longer up to what I used to be. Guess that is why we get tractors to do the work.
What price range do you think I would need to look at? Or better put I guess, what does a good working 420 or 430 go for?
I don't mind refinishing and repainting the tractor at all. My wife kinda wants to do that with me as a project, so appearance is not really that important.
There is nothing outside a front end loader that could carry those concrete chunks as well as large amounts of flower bed dirt from one side of the place to another is there?
Thanks again. I find this community to be a great place full of real people. After 30 years of musicians and fake people I want you all to know that you people are real.
Thanks again
Tom
MIKE HANLEY
10-24-2003 07:56:55
 Re: Re: Re: Can I afford a John Deere??? in reply to Tom Williams III, 10-24-2003 06:23:49
Click on to the want ads and photo ads at the left of this site and also post a want to buy ad. The JD loaders for the 420/430 such as the JD 35 (a 36A and a 45W will also fit the 420/430) had a breakawy of about 2400# and a lift to full hight of about 2000#. I hope you buy a JD as the engine sound alone is worth the price of the ticket.
Jake
10-23-2003 15:40:01
I would stay away from an old two-cylinder tractor with a hand operated clutch. You will find a conventional foot operated clutch much more convenient for loader work and other tasks.
Now I do have a JD B with matching implements from the same era and have fun playing with it but for a serious utility work tractor I'd want something much more modern.
MK
10-23-2003 22:14:13
 Re: Re: Can I afford a John Deere??? in reply to Jake, 10-23-2003 15:40:01
My dad bought a 630 2cyl in '73 w 6000hrs. He mounted a Duall ldr on it and he/we used it for choring,bales,manure, etc until it got parked in '91 w 17500hrs. I bought a 2750/245mfwd to replace it. I don't disagree for a minute that a foot clutch is nicer but a hand clutch worked fine for all the work we did w the 630.
John
10-23-2003 15:17:53
I have a J.D. model 60 with live PTO and hydrolics that serves as my work tractor and does very nice. I'm sure others will have a differant opinion though. This tractor replaced a Farmall H which does not have live PTO. I would give the edge to the 60.
