3 cyl. 830 power steering
wassaw
10-25-2004 19:41:07
Under the adjuster, under the steering wheel, are you suppost to see a retaining ring? I have some up and down slack in my steering column and there is no retaining ring I can see.
david val
10-26-2004 03:23:52
 Re: 3 cyl. 830 power steering in reply to wassaw, 10-25-2004 19:41:07
if you have power steering on your 830, the up and down 'play' is actually operating the valves in the housing so don't try to 'eliminate' it.
david
wassaw
10-26-2004 17:20:55
 Re: 3 cyl. 830 power steering in reply to david val, 10-26-2004 03:23:52
OK... I replaced the tierod ends and bellcrank bearings and made a new acting tractor. THANKS
