How to install inner hub bearing?
Kurt JDB
10-25-2004 16:33:31
I am about to install new front wheel bearings in my '52 B. should the inner bearing be installed directly behind the spacer that holds the felt gaskets, or should it be pressed in as far as it will go?
Kurt
Mike M
10-25-2004 18:09:33
 Re: How to install inner hub bearing? in reply to Kurt JDB, 10-25-2004 16:33:31
The bearings need to be installed until they bottom out against the shoulder inside of the hub on both the inner and outer bearings.
Kurt JDB
10-26-2004 04:44:08
 Re: How to install inner hub bearing? in reply to Mike M, 10-25-2004 18:09:33
Hi Mike. The reason I asked this question is that one of the Hubs on my roll-o-matic front end has worn into the spindle/knukle about 3/8 of an inch. The hub now sits so far onto the spindle that the cotter pin does not even touch the spindle nut. When I removed the hub, the inner bearing was pressed all the way in, which allowed the hub to bear aginst the knuckle. It dosn"t make a whole lot of sence to me why it should be this way. When I measured things, it seemed to me that if the inner bearing was located immediatly behind the spacer, that the hub would be at the right point on the spindle.
Guess I"ll pull the other side and see what"s going on there.
Kurt
