JD 4010 white smoke
wolfe in tx
10-25-2004 00:30:10
I started my 4010 this morning and it started smoking. White smokeing bad. What could it be head gasket water leaking or fuel thanks for your help
txblu
10-25-2004 09:20:06
 Re: JD 4010 white smoke in reply to wolfe in tx, 10-25-2004 00:30:10
Been cool here lately. White smoke is water vapor and could be coming from several places..... let"s hope it"s weather induced. Should clear out in a couple of minutes. The colder it is, the longer you"ll have to run to dry it out. On really cold days, I used to fire up my 800 cu in, 400 hp Cummins and it would white smoke till I got out on the road and put the whoopie to it.
Pop radiator cap with engine running and see if there are any bubbles in the water. Bubbles mean combustion gas getting into water meaning head or sleeves leaking water.
Water in fuel, not likely. 4010 uses a dual fuel filter that not only separates out water but filter media openings too small for water molecules to pass thru.
HTH
Mark
Leland
10-25-2004 20:43:26
 Re: JD 4010 white smoke in reply to txblu, 10-25-2004 09:20:06
Only a 400 is that even considered a engine in texas,I always heard thing are bigger in texas. but wait until you get a hold of a 600hp cat it will make you cream your jeans. On old us 36 in ILL at the draw bridge from a dead stop loaded for bear with hogs you top hill at 57mph what a engine git ya one.
txblu
10-26-2004 11:56:14
 Re: JD 4010 white smoke in reply to Leland, 10-25-2004 20:43:26
I'm sorry, but it was in a '79 Int cab over (pretty truck) at that and the time span was '92ish. All I could afford at the time.
Mark
leland
10-26-2004 13:09:20
 Re: JD 4010 white smoke in reply to txblu, 10-26-2004 11:56:14
Don't worry I am not running you down.But when I went thru texas with a 400 ,those localboys passed me like I was backing up. Only state where you can drive all day and still be there just like driving from St Louis to DC it's a huge state.sorry about your virus but go to www.pandasoftware .com that platimun is well worth the money and with a card to pay for it you can down load quick then jump onto www.webroot .com check out spysweeper with window washer good program .have not had any probs since I installed it good luck keep the shiney side up.
txblu
10-27-2004 07:41:55
 Re: JD 4010 white smoke in reply to leland, 10-26-2004 13:09:20
Yes it's large and yes they speed.
Thanks again for the 'puter tips.
Am headed to the toy store this afternoon.
Mark
agri_con
10-25-2004 01:11:25
Sounds like water to me,how much blow-by out the breather do ya have?Is there an oil film or even bubbling out the radiator?Milky looking film on your dipstick?An easy quick check if ya have one available is a cooling system pressure tester,this test can sure save ya alot of aggrivation.If ya think fuel is a possibility crack loose each injector line as the machine is running to see if any change in the smoke prob occurs.Are your air filters clean?Just some basic ideas for ya,but generally a thick white smoke is water,radiator tester will tell ya alot,deere's are noted for there liner probs,so keep that in mind.
