4440 starter replacement
Steven John
10-24-2004 19:47:47
The started went up on the 4440. for a 40 series it starts very hard when temp below 50 degrees. I was wondering if anyone has ever installed a new style starter like from an 8000 series JD? They are a gear reduction starter I think. The hole pattern is the same as we bought a 4010 with this style starter on it. That tractor sure starts good. Just wondering if it would be worth the extra money for the new style starter or to fix the old. SJ
buickanddeere
10-24-2004 22:07:23
 Re: 4440 starter replacement in reply to Steven John, 10-24-2004 19:47:47
I would like to know too. There has to be a way to mount a huge starter onto the new Generation tractors such as the 4020, 4430, 4440 etc. That will spin the engine at idle rpms and start in sub zero weather.
HTR
10-25-2004 10:11:17
 Re: 4440 starter replacement in reply to buickanddeere, 10-24-2004 22:07:23
Check the Iskra web site. We replace all the tractors and combines with these, when have trouble with starter. They are not huge, but will crank like nothing else, and we don't use the gear drive models. More when I have more time.
buickanddeere
10-26-2004 12:15:34
 Re: 4440 starter replacement in reply to HTR, 10-25-2004 10:11:17
No Iskra dealers listed up here but the product looks interesting if priced right. I wonder why so many manufactures size the starting and electrical systems for use in sub tropical areas? The Iskra AZG models in the 12V & 24V versions are the highest HP units offered. 5.0 & 6.5 KW ratings. They are a gear reduction drive with all electric windings. They are even offered in 12 & 24V with isolated windings rather than using chassis as a return. Ideal for the 12V/24V sytsem used in early Deere diesels.
