Go along with Randy"s assessment. Had 20, currently have 10. 20 was LP and 10 is diesel so I can"t comment too much on performance comparisons even thought there is a book hp difference of about 20 hp. (~76 vs 96 pto). 10 was JD"s modern (for the time) tractor, new design. As I recall it was the 1st big design after the pop series. Light weight and tough, smooth running with it"s multicylinders. Made it for 2 or 3 yrs, 61 to 63 (mine"s a 63) then built the 20....for some 10 years thereafter. My elect is OEM 24 volt. Took a little getting used to because it is essentially a -12v system stacked on top of a + 12v system. The gen and voltage regulator are 24 volt but to get the batteries to charge evenly, they split the load to 2ea 12 volt ckts....example lights on the right are on one (say +12) and lights on the left are on the other (-12). I do remember that the dash is on the - supply. If converted, the lights could be summed up as they don"t care about the polarity. I think the starter is 12v anyway (think) so that"s a no brainer. Only thing is the charging system. Would need an alt and volt regl if the alt didn"t have it built in. Thats about it. Both great tractors. Some like the later models better, but who wouldn"t. The 4200 thru 4400 series is great. Just happens I can"t afford them. The rears for the 10 are 16.9x34 while the 20 is 18.4x34. Ran both and can"t tell a lot of difference. Tire mfgr"s can make a big difference on what a particular size looks like when you stand there and look. Good luck. Mark
