Gear oil for a 730 - GL1?
Mark730
10-23-2004 17:01:11
I need to pull the powertrol housing in my new 730. Gear oil in the pto clutch. Since I need to drain the trans oil anyway, I want to refill with the "Right stuff." Does the 30 series require GL-1 or can I go with a GL-5 straight 90? If I need to go with GL-1 should I go with 140 wt? Advantages? Disadvantages? Thanks!
Bob in GA
10-25-2004 13:00:00
 Re: Gear oil for a 730 - GL1? in reply to Mark730, 10-23-2004 17:01:11
Mark:
I have a 435 and posed the same question a couple of years ago. The consensus then was that I should use GL1. It seems that it sticks to the gears better. I put 85w-140 and noticed 2 things almost immediatly. 1. The gears were louder, you could hear more of a whine. 2. Rear axle seals started leaking. When I chage it this fall I am going to 140 Wt Gl1 in mine.
Bob
