GW Trouble
Duben
10-23-2004 16:07:05
Started my GW and all was fine until I opened the throttle a bit and the governor took off - must have been going 1500 rpm for just a second or so and then backed down to an idle. The next time I opened the throttle it backfired twice and died. It started again and this time when I opened the throttle a bit there was one big backfire and it hasn't fired since. There is gas and spark. Any ideas as to what's going on or where to look would be appreciated.
Garland
10-24-2004 16:24:49
 Re: GW Trouble in reply to Duben, 10-23-2004 16:07:05
Duben sounds like you might have govnor problems,I had one to kick back and break the cam gear. Those litle ball bearing in the govnor are probably your problem if you take it down replace all the ball bearing,also there is one on distributor side(Mag) it's a pill to change you have to press the assembly apart. Also check cam gear if it isn't broken make sure those three little bolts are tight and locking plate in place. If you need anymore help give us a shout. Gman
