'51 B, bad steering, missing spindle rivets, what
Kurt JDB
10-23-2004 15:30:28
I have a '51 B with a roll-o-matic front end. steering is real bad, and amoung other things, when the wheel are straight ahead, the sector gear is not centered.
At the suggestion of Mike M, I checked the rivets that pin the verticle steering spindle to the roll-o-matic housing. One rivet is missing and I can see that the shaft has twisted and dropped in the housing.
Does anyone have experience in resetting these rivets? Is this a job for a machine shop?
Kurt
Mike M
10-23-2004 18:40:42
 Re: '51 B, bad steering, missing spindle rivets, w in reply to Kurt JDB, 10-23-2004 15:30:28
It sounds like you have found your problem. I have heard of this before,but I have never had to fix one as of yet. I think you may be able to remove the other rivet and have someone press it out then press it back in in alignment and put in new rivets or use bolts. Or you could find a good used one and replace it.
