remote hydraulics 301a
aktom
10-22-2004 21:33:17
third party image
I would like to add a hydraulic valve and couplers to my 301A industrial tractor. I want it for hydraulic top link and to run log splitter.
From looking at other similiar tractors and parts diagrams it look like you get pressure side at the relief valve under foot rest and return up under seat by rockshaft. Looking for a little more detail on plumbing and parts.
I'm pretty sure this is a closed center system.
question is what kind of valve would be required and are there any good sources out on the web to get valves and info on this. OEM doesn't look like an option, too much $$.
Also what would be a good choice for top link cylinder bore and stroke.
thanks
Jonathan in MA
10-23-2004 13:49:43
 Re: remote hydraulics 301a in reply to aktom, 10-22-2004 21:33:17
An idea for some of your questions...First , it is a closed center system , so find a closed center valve from a local supplier or one of the various catalog outlets...and where to connect may be accomplished by crawling under a 300 , a 310, 310A, 310B, 400, 410 backhoe and look where the backhoe is plumbed into. The pressure line comes off the back of the pressure contol valve (priority valve) and the return enters the horizontally mounted filter canister. all the above mentioned machines are basically the same hydraulically ...I see one in the background but can't squint enough to tell what it is...
