2840 hi lo housing busted
jerryGA
10-22-2004 20:10:03
i finally split my 2840. the housing on the hi lo assembly was busted where the shaft end meets the bell end. Also, i noticed that the splines on the shaft that went through the housing were really worn. should i replace shaft with worn splines and could that have cause the housing to bust? are there aftermarket or online parts available?
thanks, jerry
HTR
10-23-2004 20:31:34
 Re: 2840 hi lo housing busted in reply to jerryGA, 10-22-2004 20:10:03
Jerry, have you taken the planatary unit out of the bell to see if there is any damage to the gears? How is the housing and bushing that carries the weight of the unit? If the splines on the shaft, that goes into the pressure plate and clutch are worn, you should check the splines in the pressure plate and clutch, and replace what is worn.
I don't think there are any after market parts for the 2840, and probably won't find any used parts.
Parts are quite expensive for the unit. Silver tractor in AL makes a HI LO eliminator for the 2840, about $1500. You lose half of your speeds.
jerryGA
10-24-2004 19:20:41
 Re: 2840 hi lo housing busted in reply to HTR, 10-23-2004 20:31:34
thanks for the info HTR. i've priced the housing and shaft online at jdparts and found that they are quite expensive. do you have contact info for Silver in AL? do you lose lo or hi with this replacement? if anyone else has any information on salvage yards that i might call or new part dealers that are more reasonable PLEASE let me know.
thanks, jerry
HTR
10-25-2004 19:57:14
 Re: 2840 hi lo housing busted in reply to jerryGA, 10-24-2004 19:20:41
SILVER TRACTOR PARTS ROUTE 3 HWY 40 HENAGER AL 35978 PHONE 205-657-5191 WATTS 800-828-1656
