JD 60 Transmission Problem
Bruce E.
10-22-2004 19:50:40
I have a 1953 JD 60 with tranny trouble. Everything seem be be fine as long as it is in R,1st,2nd and 4th gear but when I cross over to 3rd,5th and 6th gear and start to ingage the clutch it grinds,vibrates and don't want to move. I like to have never got it back to the left side of the quadrant,but when I did it worked fine. Where do I start?
Thanks, Bruce E.
Bruce E.
10-23-2004 23:09:22
 Thanks in reply to Bruce E., 10-22-2004 19:50:40
Thank Ya'll
JDPete
10-23-2004 08:38:51
 Re: JD 60 Transmission Problem in reply to Bruce E., 10-22-2004 19:50:40
When you shift from one side of the quadrant to the other, you are actually shifting a gear inside from low range to high range. The gear for some reason isn't engaging completely. This could be caused by normal wear or the bearing near this gear could be getting worn.
You may be able to shift and get it engaged by just making sure you move the gear shift completly across until it hits the quadrant before you move it upward. If this doesn't work, post back and we'll help figure it out.
old
10-22-2004 21:44:19
Can't help with the fix but if you need parts for it I probably will have them, I have a 1955 60 I'm parting out.
