Information on john deere starter
Bill from wisc
10-22-2004 10:46:40
I have been on a serach for a john deere starter that was used on old feild choppers with a continental power unit. Dealer claims its been obsolete since 1971, I dont have a starter to compare it to. its a three bolt and the deere number is a22335 and delco is 1109472, No luck at any of the auto rebuilders. Any cross reference numbers would help. Thanks Bill
buickanddere
10-23-2004 10:09:25
 Re: Information on john deere starter in reply to Bill from wisc, 10-22-2004 10:46:40
Starters are generic and only have to bolt onto a few kinds of mounts. Any old delco starter with enough cranking power and the proper snout and drive will do just fine.
Bob
10-22-2004 22:03:16
Are you missing the complete starter, or what parts are needed to repair your's?
Also, there are places around the country that can rebuild and return an obsolete starter. Westling in Minneapolis is one that comes to mind, and they do work with of-road starters. You'd probably have to find a dealer for them in your area to send it in for you, if you actually have the old starter.
twopop
10-22-2004 17:53:34
can you locate the engine model no. there were a lot of continental engine used in fergusons,massey harris.could be you could find a prestolite starter
bill from wisc
10-22-2004 19:24:48
 Re: Information on john deere starter in reply to twopop, 10-22-2004 17:53:34
I have tryed that with no luck. Unless someone can cross the delco number to another number. The engine is a f162 but the rockford clutch unit is different than the ring gears used on other farm equipement and tractors.Thanks Bill
cannonball
10-23-2004 05:22:53
 Re: Information on john deere starter in reply to bill from wisc, 10-22-2004 19:24:48
what about a early model welder...just a thought..have nice day may god bless
bill from wisc
10-23-2004 06:08:10
 Re: Information on john deere starter in reply to cannonball, 10-23-2004 05:22:53
Thanks for the thought about a early model welder, I tryed that.On this unit the flywheel is different so those wont work, I dont have a starter other wise I would have this rebuilt,The unit never had a starter put on it. Once I overhauled the engine I want to put one on.John deere supplyed the starter(not the continal company or rockford clutch company)I have made what seems like a hundred phone calls with no result. I have spent hours at a tractor junk yard trying to see if one would work by adding a spacer but so far no luck. The problem was that very few farmers installed a starter on this feild chopper thanks for the help Bill
cannonball
10-24-2004 06:55:07
 Re: Information on john deere starter in reply to bill from wisc, 10-23-2004 06:08:10
the early welders used a spacer..the starter looked like one on a 420 jd.. was told that an early dodge would work on welders but would not so you might try early dodge with flathead engine..have nice day may god bless
