How does this tractor run then?
Butch ( PA )
10-22-2004 03:02:22
This summer, I got my dad's 49' "A" running. Only now I re-read a part on timing of the magneto and find out my spark plug wires are switched. The top wire is supposed to go to the Left side (flywheel side), but it is going to the right side instead. Will I need to take my magneto off and re-time it? Eph 3:20
Butch ( PA )
Ravgardner
10-22-2004 05:19:34
 Re: How does this tractor run then? in reply to Butch ( PA ), 10-22-2004 03:02:22
Well, you could do that. Or follow the old saying, "If aint broke, don't fix it." It is likely that the magneto was installed 180 degrees out of time. If you remove it and follow the proper proceedures found in the IT manuals, or JD Engine Guide or the posts on the discussion board you will then have it timed properly and be able to put the wires in the proper places. But it will run fine the way it is, and it is good that you know what is needed to make it "Proper." Just run it a while and enjoy it. When the snow blows and there is lots of spare time, pull the mag and give it a good look over for other parts that may need help, such as the impulse spring, coil or points and condenser. Then put her back the right way.
