JD 510D Help!
Kevin H
10-21-2004 22:12:25
Hi guys, I'm sorry if this post is a little long but here goes. A guy that I know has a JD 510D. It's old,probably out of the 60's. The problem was that it would not run right. I started it up and held the throttle down. It would run at 1500 rpm's and loop down to 500 and back up to 1500. After speaking to a few people they told me as long as the fuel supply was good that the injection pump was bad. A common problem with these engines I'm told. I replaced the injection pump with a rebuild from a local pump shop. I started it up and it ran fine. I called the owner up and told him to pick the tractor up. He drove away and got a few blocks down the road. The tractor slowly lost power and RPM's until it would not respond to the throttle. It will just sit there and idle. If you shut it off and waite a couple of miniutes it will run fine then slowly loose RPM's again within 2 miniutes. I had a fuel pressure guage tapped into the fuel filter housing and it reads a steady 5 lbs. even when loosing RPMs. I replaced the fuel hose from the fuel tank to the lift pump thinging that it may be calapsing inside,still no good. I blew air through the return lines,still no good. I wish that I could test fuel pressure right at the injection pump but I can't find a T that will work. If I have steady fuel pressure to the injection pump and the return lines are open it has to be the rebuilt pump that I bought right? Any suggestions?
thejdman01
10-22-2004 10:20:24
 Re: JD 510D Help! in reply to Kevin H, 10-21-2004 22:12:25
we have a 510d loader/backhoe and had sort of similar situation. ended up the hydraulic pump wasnt relieving pressure and hence the surging or just plain pull down. might be something to look at as a very last resort if its a backhoe
3010 Ken
10-22-2004 04:56:41
Morning,Kevin. My Dad has a 2640 that did the same trick about a year ago.Asit turns out the return lines from the nozzles had debris in them.I think Bob is on the right trail.We replaced all of the small tee fittings and hoses after running the engine with return cicuit disconnected.The debris we found resembled coffee grounds!Small bits of plastic or chuncks of rubber hose that were hard.Good luck to you and let us know how you made out. Kenny
agri_con
10-22-2004 03:29:09
Had this same prob not too long ago,turned out to be a bad lift pump/mecahical fuel pump,was sucking air.Wouldn't leak externally tho,performed all the same tests as you,finally replaced the mech,ran great,this was on a 2640.
Bob
10-21-2004 23:04:07
Have you tried running it with the fuel return line disconnected from the injector pump?
A clogged or squashed return line will cause problems like you are having.
Kevin H
10-21-2004 23:30:29
 Re: JD 510D Help! in reply to Bob, 10-21-2004 23:04:07
Hi Bob. No I have not tried that. I was thinking that tomorrow morning I was going to take and drain the fuel tank and look inside. I could then run the engine out of a bucket of fuel instead of the tank. I could then see inside the tank, and with the engine running I should see the fuel returning to the tank right? If I see fuel returning to the tank and I crack the fuel return line off of the injection pump and if I'm getting fuel return there then the return lines should be OK right? The only other thing that I could figure would be to crack the fuel supply line loose to the injection pump while running and see if it has pressure in it. While I got you let me ask you another question. The manual showed a spring on the bottom of the injection pump shaft. The old pump did not have one and the new pump did not come with one. It looks like the spring just helps push the pump out when being unbolted. What does the spring do? I can E-Mail you a part explosion of the spring in question if you don't know what I'm talking about.
Bob
10-22-2004 06:47:10
 Re: JD 510D Help! in reply to Kevin H, 10-21-2004 23:30:29
Just unhook the return line and start 'er up! Then you'll know if your problem is a plugged return line.
If you're worried about the fuel mess, slip a piece of plastic hose on the pump fitting, and catch it in a container.
The parts book shows the spring for all serial numbers. It probably is sort of an anti-rattle thing, to keep the pump shaft from bouncing around, on the vertically mounted pump and I doubt it's absence is causing your stalling.
If you decide to put the spring in, it still shows as a good number at Deere... #R44686, @$2.10.
Kevin H
10-22-2004 23:42:27
 Re: JD 510D Help! in reply to Bob, 10-22-2004 06:47:10
Hi Bob, Sorry that it took me a while to get back with you guys. I was busy Friday. It's fixed! It was the return tube. I removed it again (I blew air through it once before) and took it to my shop. I then ran an 1/8 inch drill bit down the 4 little return tubes from each injector. I blew through the lines after running the drill bit and put it back on the tractor. It started up and ran great. I want to thank you and Kenny for the tip. This is the first time I posted on this forum. I don't usually work on tractors. I figured someone else had to have ran accross a problem like mine before. Thank you guys for your help.
