Rick, the switch shouldnt have too much to do with your no charge condition, unless you have major miswiring problems, that is, most no charge problems are either the Generator or Voltage Regulators (VR) fault. The tractor was originally POSITIVE ground, how is yours wired now????? BASIC WIRING: BAT on VR to load (NOT to battery) side of ammeter. The ammeters other supply terminal has but one wire and it receives battery voltage usually from the starter switch. BOTH sides of ammeter must always read HOT battery voltage. FLD on VR to Gens Field post. ARM (or GEN) on VR to Gens Armature post. LOAD (if you have a 4 wire VR) up to the BAT input on the switch, its what feeds loads like lights and ignition etc. If you only have a 3 wire VR that doesnt have the 4th LOAD terminal, the load side of the ammeter feeds the switch and its loads, thats the same terminal connected to BAT on the VR. BASIC TROUBLESHOOTING A. Preliminary 1. Make sure BOTH the Gen and VR are well grounded, they need to be for charging. 2. Make sure the belt is good n tight and not slick or glazed. 3. POLARIZE by momentarily flash jumping a wire from the VR's BAT terminal over to its ARM terminal and you should get a small spark. 4. Make sure the BAT terminal on the VR always reads hot battery voltage, thats where n how the Gens output gets to and charges the Battery via the ammeter. IF ITS NOT READING HOT make sure the wire is there to the ammeters load side and that BOTH sides of the ammeter are always HOT. 5. The battery must be good and capable of accepting a charge. Be sure there's electrolyte above all the plates and that no cells have a gray or milky color. B. TO SEE IF ITS A GEN OR VR PROBLEM 6. Start the tractor and ground the Gens Field post to its case ground. If it charges then,,,,, ,, either the VR is the problem,,,,, , or the wires missing from the Gens Field post to FLD on the VR,,,,, ,,or the VR isnt well grounded. 7. If it still dont charge (leave the Field grounded) next temporarily connect the VR's BAT terminal over to its ARM terminal. If it charges then, the VR's cutout relay is likely bad. 8. If still no charge, you have essentially by passed the VR's function, so if all else above is good and youre wired correct and the battery is okay, the Gen is likely the problem. Typical Generator problems are brushes worn down too low,,,,, ,, or the brush hold down springs and assemblys are stuck or corroded and NOT holding the brushes tight down against the commutator (Try air and WD 40 etc to insure they are free n push brushes down),,,,, ,,,or the armature is bad/shorted,,,,, ,,,,, ,or the commutator is bad,,,,, ,, etc. etc. etc. Post back any questions and your findings, Good Luck n God Bless John T Nordhoff in Indiana
