Can't start the B
Scott
02-07-2004 17:42:05
I have a 1945 styled B, I bought not running, not stuck. I didn't have spark initially. Replaced coil (per prior owner), plugs, wires, cap, rotor button. Mag snaps good, seems to have good spark to both plugs. Had carb rebuilt at dealer. When cranking haven't been able to get it to fire off. Have compression releases open, seems like alot of fuel spraying out. Have switched plug wires back and forth still no firing of cylinders. Maybe too much fuel? What should plugs be gapped at? Any ideas on what to do next. Timing? How do you set?
will
02-08-2004 17:37:17
 Re: Can't start the B in reply to Scott, 02-07-2004 17:42:05
points set at .015 and plugs at .030 If those plugs ever got wet, I would try a new set of somewhat hot plugs (Champion D21) until you get it running and starting good. Do you have good compression? It takes fuel, spark and Compression.
JM
02-08-2004 05:02:16
My 1951 B will not start if the plugs have been fouled by engine flooding.
No matter how well I clean the plugs, it will only start with new plugs.
I have seen this happen on other engines as well. It seems to have something to do with unleaded gas and the ceramic of the plug tip.
Short answer, fix flooding problem and get some new plugs.
Good luck.
JM
1951 B, 1955 70 Diesel
Russ
02-08-2004 04:43:40
B in need. Dry clean spark plugs and a pull start if you can line up some help. Just prior to the pull a 3 second puff of ether once the oil bath filter if taken off. Good luck.
Pappy
02-08-2004 01:22:28
If you have a lot of fuel spraying out the petcocks, you might have wet plugs. Change plugs and see what happens.
Bill R
02-07-2004 23:42:12
Scott, pull starting it would be a good idea, but if you are up to some more cranking, take off the carb-to-oil bath air intake pipe and see if she pops then. The air cleaner may be gunked up and need to be cooked out. Recently had a '44 A handcranker that had been sitting, loose but not running and when i had everything ready to go she wouldn't pop, took off the air pipe and she'd pop. Nice feeling to know that air cleaner is all cleaned up anyway.
Bill R
A // B // GW // R Diesel
old
02-07-2004 19:26:43
sounds like its flooded, I'd pul start it most of them old ones don't like to start if they haven't run in a long time. I had to do that to my 35B and now it starts on the 5-7 pull of the flywheel
Perry F.Hartnett
02-08-2004 14:15:34
 Re: Re: Can't start the B in reply to old, 02-07-2004 19:26:43
Always shut off the fuel control valve and let the carburetor run dry when stopping tractor.Don't turn on until you are ready to start [immediately prior to].It sounds as if the carburetor float is sticking and overloading the cylinders with fuel.I neglected to do this on my Model"G" and wound up with both cylinders filled with gasoline and a considerable amount in the crankcase. Good Luck,Perry
