Fire
Green John
10-21-2004 11:28:20
My prize JD model B was in a barn fire on Sept 1 the fire burned all the tires off. My question is are there any internal rubber seals that might have been destoryed.It is a hand crank model it has good compression I hope to save it just by replacing all external parts that are burned.Any help on what to look for I will be thankful.
Maark
10-21-2004 11:52:30
 Re: Fire in reply to Green John, 10-21-2004 11:28:20
There is a rubber o-ring at the rear of the fan tube, seals at the front of the fan,probably need to replace the crankshaft seal,along with all the external gaskets. You might want to check the gov. weights as well.
