Best loaders for a 4230
Gorilla
10-21-2004 11:11:47
What is the best loader to get for my 4230? I will leave it on a lot of the time but want to be able to take it off fairly easy. Am considering a JD 158 but not sure how hard it is to take em on & off.
TD
10-22-2004 06:02:32
 Re: Best loaders for a 4230 in reply to Gorilla, 10-21-2004 11:11:47
A JD 725 loader is an excellent loader for a 4230, it is the same as a 158 but newer and much faster to take off. You only have to pull two pins one on each side of the loader and your hoses and it"s off. I had a 725 loader on my 4020.
megamoodairy
10-21-2004 20:08:59
I have a Koyker 565 it mounts fast can be color matched to your tractor 4000lbs of lift capacity and 6000lbs of break out force lifts about 13 ft in the air and bucket will completely dump at that height and anybody with a welder can make your own attachments(the brackets are only 1/4"x2 angle iron and 1/2" flat steel)you don't hafta order them from a dealer. I paid about $5000 for the loader with an 8ft bucket and joystick controls. It cycles much faster then my father in laws 58 loader(mounted on a 4320)My loader is mounted on a Massey Ferguson 1100(eqiv to 4020).
David in MD
10-21-2004 19:45:46
I"ve got a 148 on my 4230 and it"s a good match. The 158 is heavier, lifts more, lifts higher, but also sticks out in front of the tractor further. I haven"t found where my loader interfered with use of the tractor so haven"t removed it. Only reason I could see to take it off would be for working in wet ground or to make repairs. Removal requires removing eight 3/4(?) bolts, 4 of which are behind the loader arms. I would recommend you get one with a joy stick control and supply it from a power beyond block so you don"t tie up your remotes. True quick attach and self leveling loaders are nicer but usually cost quite a bit more. 148"s sell for $2500 while $158"s average $3000 around here.
Jason Z in MO
10-21-2004 11:44:11
I picked up an Allied 595 loader for my 4230 about 6 years ago. I did a lot of looking and found the Allied to have a very rugged frame mount. It is quick attach with two bolts but when its mounted, its staying put! They have quick attach attachment mounts. You can buy just the quick attach brackets and make your own attachments. Thats what I did to make a loader spear. Here is there web site, the parent company is Buhler.
Link
click on the little loader on the top...
Also, if you order it, they will paint it JD green and it looks sharp on the tractor. Mine even came with some yellow pen striping.
Mike M
10-21-2004 11:35:21
I have a 158 on a 4020 and I don't think I would want to take it on and off much as you have to remove bolts to do it. I saw a loader on a 4020 called an easy-off from canada I think. It looked easy to take off and also heavy duty almost too heavy duty for a 4020.
Gorilla
10-21-2004 20:52:32
 Re: Best loaders for a 4230 in reply to Mike M, 10-21-2004 11:35:21
THanks for the info. Im going to check out the 158 & the koyker for sure. Appreciate the help.
