2010 hydraulics solution
farmergreen
10-21-2004 10:59:14
Rebuilt rockshaft control valve following hyper extended rockshaft that busted rockshaft housing. Located used housing. Changed all fluids and filters. First time out one of new snap rings on a control valve came off filling PTO clutch housing with fluid. Once problem was diagnosed and the old rings put back on, all of the hydraulics and power steering stopped working. As posted several times by others here, never underestimate what a filter related problem can cause. Mechanic suggested glueing detached seal to rear of transmission filter. Rockshaft and power steering working like new again.
steveVT
10-27-2004 13:34:20
 Re: 2010 hydraulics solution in reply to farmergreen, 10-21-2004 10:59:14
it wasn't until reading this forum that i took to heart the importance of the transmission filter (just cleaned up the one in the tractor with carb cleaner spray). i have rebuilt and readjusted the rockshaft valve, had the pump rebuilt, and the rockshaft and power steering still no go. i was relieved to hear that the filter could be the problem - it's my last best hope and i even paid top dollar for the JD part.
farmergreen
10-27-2004 13:55:04
 Re: 2010 hydraulics solution in reply to steveVT, 10-27-2004 13:34:20
I"m told the new filters have the seal installed on the end. When I changed the fluids, the rear seal just plopped out on the ground. I didn"t have a clue where it came from. I looked at a parts manual and saw that it was located between the end of the filter and the end of the cannister that holds the filter. Attempts to put the seal in place then insert the filter never worked. Once I glued the seal to the rear of the filter (silicon gasket sealer), the hydraulics began working again. Good luck.
steveVT
10-28-2004 05:36:20
 Re: 2010 hydraulics solution in reply to farmergreen, 10-27-2004 13:55:04
thanks again because that was more good news indicating that my problem may have been the seal. when i removed my transmission filter the last time the seal was all "katty wampus", misshapen, and just flopped out. during re-installation it was so slippery and distorted that i'm not sure i obtained a seal. and you're right, i noted that the new JD filters have the seal glued onto the end. ... new filter, proper seal, how can i go wrong. i'm sure there's a way.....
