Fuel blowing out of petcocks on JD A
Padd
10-21-2004 10:53:23
When starting my hand start A, before it will fire the first time the cylinders seem to load up with fuel and blow it all over me and the plug wires before I can get it to start. Once started it runs like a top. What is the problem with this? It makes me smell pretty foul too.
fixerupper
10-21-2004 20:49:52
 Re: Fuel blowing out of petcocks on JD A in reply to Padd, 10-21-2004 10:53:23
My '35 A does the same thing. If it doesn't blow a little fuel out the petcock, then I know it isn't choked enough. There is a fine line here, though. If it blows a lot of fuel out, then it is flooded and I'm getting too old to turn the flywheel enough times to start it if it does that!
RayP(MI)
10-21-2004 19:38:13
When you shut down tractor try closing the valve at the fuel tank, and let tractor run carb dry. Could be that carb is leaking fuel down when engine isn't running. May need to clean and/or repair carb float and valve assy.
Hayfarmer
10-21-2004 11:21:57
Each 2 cylinder tractor seems to have it's own best starting sequence. On my 1938 G, I put the choke on full, roll it about 2 or 3 times and it fires. I then move the choke to 1/2 and roll it again. Throttle in about 1/2 way position. Your A may be different. Sounds like you are getting too much fuel in cylinder. Either you may be chokeing it too much for too long or there could be fuel leaking into the cylinders from a bad needle seat/float problem. I would try less choke. If it starts fairly easily the way it is just turn the LH petcock down away from you.
farmallman
10-21-2004 12:54:13
 Re: Fuel blowing out of petcocks on JD A in reply to Hayfarmer, 10-21-2004 11:21:57
What does LH stand for? Left ???
F-I-T
10-21-2004 14:15:05
 Re: Fuel blowing out of petcocks on JD A in reply to farmallman, 10-21-2004 12:54:13
...left hand...
farmallman
10-21-2004 14:18:26
 Re: Fuel blowing out of petcocks on JD A in reply to F-I-T, 10-21-2004 14:15:05
left hand as in left side of tractor or something i have no idea about? Thanks
Hayfarmer
10-21-2004 21:50:59
 Re: Fuel blowing out of petcocks on JD A in reply to farmallman, 10-21-2004 14:18:26
All I ment was by turning the LH (left hand) petcock down away from you you wouldn't get sprayed with fuel. As mentioned above it seems like these usually shoot some unburned fuel out on starting.
F-I-T
10-21-2004 15:28:43
Left hand as in left side. On a two-cylinder JD it's synomous with flywheel side or #1.
